Fascia Or Decking First - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 09:00 PM   #1
Fascia or Decking first
I have looked around and cannot find any tips on whether I should install the fascia or the decking first. Does it matter? I plan on having the decking overhang the fascia by an inch or so if that changes anything. It is also Trex decking. Thanks for the help.
munsonr1 is offline   Reply With Quote
Old 08-09-2011, 11:17 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Run your decking first.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-09-2011, 11:41 PM   #3
Too Old
Sorry but if you can't figure that out
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 08-10-2011, 07:16 AM   #4
Rewards Points: 5,336
You can do it either way. If you do the decking first, you just need to leave it extended past the rim joists evenly around the deck and take into account the fascia thickness.
If you do the fascia first, you can just extend the deck over the board the projection you want.
Ron
B. Franklin 1759
Old 08-10-2011, 08:04 PM   #5
Framing Contractor
It doesn't matter what you do first.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-10-2011, 08:40 PM   #6
Rewards Points: 150
Interesting. We always run the facia first setting it up the thickness of the deck. When laying the deck just drop it down and slide it to the facia- eveything aligns itself. I wonder though, why would you want the deck to extend out over the facia? If you are looking for a drip edge to get the rain away from the facia, look to the Style D, Type L roof edging. Like this one:
http://www.dotmetalproducts.com/dotm...duct.php?id=12
TrapperL is offline   Reply With Quote
Old 08-10-2011, 09:28 PM   #7
Framing Contractor
Why would anyone ever put that on a deck?
Joe Carola
Old 08-10-2011, 09:38 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Exactly.
Jim
Old 08-11-2011, 06:42 AM   #9
Run the decking first. Fascia is always last. You need to install railing as well and I'm sure you don't want to go through the fascia as well. Take the trex back trust me
dvatt is offline   Reply With Quote
Old 08-11-2011, 07:17 AM   #10
kwikfishron's Avatar
Rewards Points: 586
If your decking is going to overhang the fascia I’d run the fascia first.
That way if the fascia has any crown it will be easier to work it out.
kwikfishron is online now   Reply With Quote
Old 08-11-2011, 10:12 AM   #11
AGWhitehouse's Avatar
I think the OP is talking about a "patio" deck, not a roof deck. And, on the subject of roof decks, your sheathing should always overlap the fascia board as a last line of defense against water intrusion.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-11-2011, 06:03 PM   #12
Thanks for all the replies. It looks like the overwhelming response is to go with the decking first, so that is what I am going to do. Also, thanks for the reminder on the railing dvatt. I am going with a glass railing and will need to put blocking in before I install them. I imagine it will be easier to have the rim joist open as an option to put a screw through if I need to.
Thanks again
Old 08-11-2011, 06:42 PM   #13
Rewards Points: 558
When the deck boards run over the facia you can mark a chalk line for the desired overhand and cut the boards off with a skill saw..
epson is offline   Reply With Quote
Tags
decking , fascia , order
Rotted decking, soffit, and fascia nanotech1112 Roofing/Siding 0 07-20-2011 07:45 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
12" Fascia Board Maralind Roofing/Siding 6 01-26-2009 05:26 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
