Fascia Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 07:39 AM   #1
Rewards Points: 396
Fascia board
When you go to sheet the roof where exactly do you bring the sheathing in relation to the sub fascia board? Flush or set back a little?
detroittigerfan is offline   Reply With Quote
Old 08-06-2013, 07:47 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
it depends on the pitch of the roof but ideally you want the sheathing to butt to the top of fascia board with the outer most edge of sheathing flush(plumb) to the front/top of fascia allowing roofing materials to plane out smoothly and possible drip edge to lap onto fascia.
hand drive is offline   Reply With Quote
Old 08-19-2013, 10:11 PM   #3
X2 and nail sheathing to fascia board from top as well as to the tails.
Godspede619 is offline   Reply With Quote
Old 08-20-2013, 10:08 PM   #4
Rewards Points: 2,212
If you are using an aluminium (or plastic - yuck) drip edge you are better to have it back even 1/4" then sticking out 1/16th inch.
mae-ling is offline   Reply With Quote
Old 09-04-2013, 10:32 PM   #5
it depend on the roof , what kind of roof tile, fiber cement roof? usually circumstances, the fascia board is matched with roof tile.
hocreboard is offline   Reply With Quote
Old 09-06-2013, 07:08 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
it varies from framing crew to framing crew. some guys will set the fasia board so the sheathing will hit on teh very edge of the subfascia, others will set it so the sheathing hits dead center on teh sub fascia..
by doing it the 2nd way, it will create extra tension on the drip edge which makes it harder to fit aluminum cladding under the drip edge
woodworkbykirk is online now   Reply With Quote
Old 09-06-2013, 08:16 PM   #7
Rewards Points: 454
We allways set it so the sheeting falls in the middle of the gutter board.Alot eaieser if you put the gutter board up first.Just run a straight edge down the rafter till it hits the middle of the board than nail it.
scottktmrider is offline   Reply With Quote
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
Replacing Fascia Board Cultcab Building & Construction 3 03-12-2012 06:49 PM
Fascia Board - Gutter Install handy man88 Roofing/Siding 6 02-22-2010 07:48 PM
I need some pointers about fascia board octobermoons Roofing/Siding 12 05-28-2009 07:03 AM
