Fascia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 05:01 PM   #1
Fascia
I need to replace a piece of fascia and I must remove roof edge and I am wanting to know to do this
Raygm6 is offline   Reply With Quote
Old 01-12-2012, 05:38 PM   #2
kwikfishron's Avatar
Rewards Points: 1,008
A little more info and a picture would help.
Is there gutter attached to the fascia? Do you really mean fascia or the barge board running up the rake?
kwikfishron is online now   Reply With Quote
Old 01-13-2012, 03:03 AM   #3
Retired carpenter
The roof edge shouldn't be nailed to the fascia board, but to the plywood beyond. Most probably you can remove the fascia board without removing the drip edge (roof edge). Lift the shingles gently to check.
abracaboom is offline   Reply With Quote
The Following User Says Thank You to abracaboom For This Useful Post:
mae-ling (01-13-2012)
Old 01-13-2012, 07:37 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
more than just the metal drip edge is going to have nails into the fascia. if its the actual fascia board it will be though nailed into the rafter tails and have a nail or two down through the roof sheathing midway between rafters/trusses.. if its the fly rafter , meaning the fascia on a gable end it will be through nailed down through the the sheathing and possibly have blocking between it and the gable end wall which will keep it from sagging..
if its installed the way i mentioned it will be a combination of pulling out nails with a cats paw and cutting nails with a recip saw.. not a fun task but has to be done
woodworkbykirk is online now   Reply With Quote
Old 01-13-2012, 08:45 PM   #5
Exactly, I’ve never replaced fascia or barge with no nails in it from the top.
It can usually be replaced without removing any roofing but it’s almost a surgical like procedure that maybe beyond "DIY 101" to pull off without damaging any roofing, assuming you have all of the right tools.
Fascia wood rot - how best to replace or repair? miamicuse Carpentry 4 01-11-2012 03:53 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
12" Fascia Board Maralind Roofing/Siding 6 01-26-2009 05:26 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
