Fanfold Under PVC Trim - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2008, 12:58 PM   #1
Fanfold under PVC Trim
I'm currently removing the really cheap vinyl that covers our house so it can be replaced with hardie lap siding. I want to reuse the existing 1x4 (3/4 x 3-1/2 actual) azec trim, but don't like the way the windows (jeld wen aluminum clad) project out 1/2" from the face of the trim. Would it be appropriate to use 1/4" fanfold to build-out the trim? I've built out vinyl corners that way but never tried it under trimwork.
Thanks,
-Sam
samjack is offline   Reply With Quote
Old 09-26-2008, 09:32 AM   #2
Well, I get the feeling that using fanfold to build out the trim is not such a good idea; any suggestions from the more experienced? Primed 1/4" CDX maybe or should I forget about trying to salvage the existing trim?
Thanks,
Sam
Old 09-26-2008, 11:45 AM   #3
Registered User
Termite's Avatar
I would not advise it. You should use something solid if you're building the trim out.
Old 09-26-2008, 12:27 PM   #4
I definately see your point. After giving it more thought, I think I'll rip some pvc utility trim and glue it to the backside of the existing trim. If I'm still toddling down the wrong path, please reach through my monitor and give me a whack.
Thanks!
Sam
Old 09-26-2008, 02:21 PM   #5
Registered User
Termite's Avatar
You're on the right track now. Just make sure that you properly weatherseal everything and I'd also use felt building paper behind the trim.
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
