Old 01-27-2013, 12:58 AM   #1
Doing it myself
Alan's Avatar
fan exhaust (roof flashings?)
I need to install some exhaust terminations in the roof for my bathrooms. I shouldn't have any problems actually installing the terminations (is that what they're called?) but what i'm wanting to know if there are any out there that don't slap around when the wind blows up against them.
Thanks in advance!
Journeyman Plumber
Old 01-27-2013, 01:09 AM   #2
http://www.bing.com/images/search?q=...electedIndex=7
Most of the ones I've installed had the flapper mounted to the fan housing not on the roof.
Old 01-27-2013, 10:17 AM   #3
When I did mine, I had to terminate thru the roof as well. I used 4" PVC for the run thru the attic and out thru the roof. The termination above the roof is a 90* and a 45* elbow so it points down. In the line inside the attic I installed an inline flapper similar to the ones found on the exaust fans. My local supplier has them in both 3" and 4".
danpik is offline   Reply With Quote
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 12 02-12-2013 06:00 PM
roof leaking 5 ft. below exhaust vent mayhem69 Roofing/Siding 65 10-28-2011 04:48 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
