Fake Brick Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 03:54 PM   #1
fake brick wall
could anybody help me with this? it's impossible to find something if you don't know the name.
what i'm looking for is this cheap fake brick uhh... "backsplash" kind of idea, it goes behind a woodstove to protect the wall from the heat/ look like you installed a brick hearth when you didn't. if i only knew how to search for this project, all my arts and crafts dreams would come true!
thanks!
noelcj is offline   Reply With Quote
Old 01-27-2011, 04:07 PM   #2
Rewards Points: 5,336
Check out, "brick fascades".
Ron
Old 01-27-2011, 04:24 PM   #3
Rewards Points: 558
is this what you are looking for?
you can find it here: http://www.fauxpanels.com/royal-brick/styles-brick.php
epson is offline   Reply With Quote
Old 01-27-2011, 05:22 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Throughout the industry it is known as "THIN BRICK" but other names are applied by the makers.
Buyer beware however.
Some of it (like shown in the above photo) is a casting from a mold and is really made of colored cement, this becomes an issue when a smaller piece must be cut for a filler because cutting exposes the cement edge and is ugly. Cipping can also expose the cement color.
It is also available in real brick that has been sawn. When you have to cut this type of product you still see the real brick on the cut edge.
Also be aware that not all sellers of "thin-brick" include the required "L" pieces for making corners and returns.
Search: "THIN BRICK"
XXX
Old 01-27-2011, 07:32 PM   #5
Maybe you're looking for 'Z'Brick. It comes in small sheets and looks fake as h---. I haven't seen it readily available since the late eighties, for good reason, but if you just need a 'firewall' to nail up, that's the brand name.
Dwoodsmith is offline   Reply With Quote
Old 01-27-2011, 10:08 PM   #6
Possibly "stone veneer?" I've been looking at this for a possible kitchen backsplash if I decide not to tile. Google it and you'll get tons of results. Even sold @ Lowes if ya want to take a look @ it! Hope that helps.
Waylon
Waymo is offline   Reply With Quote
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 07:41 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
creating a basement window opening in a brick wall amakarevic Building & Construction 5 01-30-2008 11:06 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
