Facia On Mono Truss - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 02:14 AM   #1
Facia on mono truss
Hi, I've been building a 20' x 20' garage with a mono truss styled roof. I've gotten to the facia point but need some advice. I know how to put the 2x6 facia on the lowest end of the mono truss, since that is similar to most roofs. The roof sheathing will overlap the facia. However on the highest point how do I get the roof sheathing to overlap while still having a bottom edge that matches the soffit on the gable ends?
Any advice would be greatly appreciated.
yamsicle is offline   Reply With Quote
Old 08-29-2012, 05:50 AM   #2
kwikfishron's Avatar
Rewards Points: 818
You donít want the sheathing overlapping the fascia. The top of the fascia should be flush with the top of the sheathing on the rake and plane in with the lowest outside edge of the fascia at the eave. You can rip the upper fascia at the angle of the roof.
You want the fascia to protect the edge of the sheathing.
kwikfishron is online now   Reply With Quote
Old 08-31-2012, 12:27 AM   #3
Thanks for that information. I'll let you know if I have any follow up questions.
Gable End Truss Offset Siding ChristianT Carpentry 7 07-29-2011 03:54 PM
Mono Truss ryllee Carpentry 3 03-14-2011 09:53 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 12:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
