Faced Or Unfaced Insulation ? - Room Below Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 10:59 PM   #1
Question
Faced or Unfaced Insulation ? - Room below porch
Hi, I'm putting in a bathroom in an exterior room that has an outdoor porch above it. The porch has a roof over it, but has open walls, so when it rains, the porch will still see a little bit of water. Below the porch there's a room that I'm putting a new bathroom in. I'm going now to put insulation in the ceiling joists, but I wasn't sure if I should use faced or unfaced. I think the porch is sealed relatively well, so I don't anticipate there will be much moisture there, but I want to make sure I do the right thing so I don't have a problem down the road. Any suggestions?? Thanks!
buchmana is offline   Reply With Quote
Old 02-01-2010, 09:12 AM   #2
Faced insulation is used for a vapor retarder, plastic for a barrier
The paper goes towards the heated space
You still want to minimize water vapor coming thru the ceiling
Old 02-01-2010, 09:29 PM   #3
Registered User
Rewards Points: 5,498
You need R-49 in the roof for your location: http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html
Are your sloped rafters above 14" thick for this glass batt insulation?
May want to think about foam or foam board: http://www.buildingscience.com/docum...aspen-profile/
Is it ventilated?
Be safe, Gary
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
upgrade with Foil faced insulation? Chemist1961 Building & Construction 3 12-11-2009 05:27 PM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
