Old 04-18-2006, 01:33 PM   #1
faced or unfaced insulation
I just built a garage with a second floor.The second floor has a bathroom with shower.I know exterior walls get faced insulation with the face towards the inside of the building.I am not sure about the bathroom,the garage ceiling or the ceiling of the second floor.Any input is appreciated.
wiggs is offline   Reply With Quote
Old 04-18-2006, 08:37 PM   #2
A Builder & Plumber
Any insulation that will hold in heat or A/C should be installed with the craft side towards the inside of the house, outer walls paper in, ceiling paper towards floor, floor paper towards ceiling, interior walls (Noise controll) use uncrafted. As far as the garage ceiling I would face the paper upwards toward the roof and install a sheet of 10 mill plastic in on the garage ceiling
Oldman is offline   Reply With Quote
Old 04-18-2006, 10:51 PM   #3
I like the plastic idea,but I won't be able to glue the drywall ceiling.Something I forgot to mention was the trusses are pre-enginered.Made just of 2x4's in triangular shapes not T.G.I.'s, the ones made with plywood and a 2x4 top and bottom.The trusses are 22in. deep.I'm refering to the garage ceiling.
Old 04-18-2006, 11:02 PM   #4
A Builder & Plumber
Well you could always install it with the paper down and install the plastic on top, then instead of gluing the plywood subfloor for upstairs just use decking screws instead. I use a screw gun now instead of nails just because it's less mess and no chance of sqeaks
Old 04-19-2006, 02:55 AM   #5
renovations
I don't understand why you would want a vapour barrier between the two heated parts of the building; if the garage is unheated then you want the vb on the "warm in winter" side of the insulation. Again, if the garage is unheated, you don't need a vb on the ceiling, the plywood will do it for you. If you put a vb on both sides of the ins. I think you're asking for moisture trouble. Just my $0.02
Bonus is offline   Reply With Quote
Old 04-19-2006, 06:50 AM   #6
The subfloor upstairs is already down.I have to insulate from the underside (first floor).When refering to the gluing it was the drywall ceiling of the first floor (garage portion).Thanks for the replies.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
Insulation - Faced or Unfaced? Ricky D Building & Construction 5 03-17-2007 09:47 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 05:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
