Old 08-01-2007, 10:02 PM   #1
F chanell install question...
Greetings,
I am replacing my old aluminum siding on my garage with vinyl and also installing aluminum soffit. I am using aluminum F channel at the house and wonder if the nail flange has to be up. The instruction call for the nail flange up, but the flange hits the trusses. Would it hurt to leave the nail flange down?
TonyW is offline   Reply With Quote
Old 08-01-2007, 11:34 PM   #2
It does not matter. The flange facing down is only a minor problem when you go to install you J trim or utility trim for the vinyl siding that is going to come up to your soffit.
warnerww is offline   Reply With Quote
Quick Question on Powerstrip Install Ferguson Electrical 7 05-06-2010 07:16 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Vent stack leak and install question bjstewa Plumbing 5 06-09-2007 10:01 PM
Soffit installation question milano Roofing 4 02-04-2006 11:13 PM
Laminate Selection & Install Question sdcards Flooring 1 10-13-2005 05:12 PM
