Old 06-21-2009, 12:43 PM   #1
External intake and exhaust vents
I want to install a couple of vents but my neighbor's wall is within 3 feet of these vents (directly facing)....is it okay to go ahead or is it against the building code? thanks for any information that you can give me.
monkeysee is offline   Reply With Quote
Old 06-21-2009, 04:51 PM   #2
It would help if you stated what you were venting and where you're located as what can be done is sometimes regulated differently from place to place. If this is a condo, there are even more regulations.
Ron
Old 06-21-2009, 05:29 PM   #3
Ron
Thank you so much for replying so quickly. One is a dryer vent and the other is for the washroom. This is not a condo but a house. I realize that every regulations differ but is there any sort of general consensus regarding this.
Thanks.
Old 06-21-2009, 10:27 PM   #4
Moderator
Bath fan- duct termination min. 3' from bldg. openings or plate line. IRC 302.2 UBC 504.5
Back-draft damper required.
Clothes dryer- duct termination- End outside in back-draft damper& no screens
Min. 3' from other building openings UBC 504.5 Smooth metal inside. No screws in airflow. 4" min. duct.
25' minus 2' per 45* bend, 5' per 90*. Male ends must face direction of airflow.
Steel duct only through fire-rated assembly. Be safe, G
Old 06-22-2009, 08:27 AM   #5
Thanks, the information that you provided really helps.
Bathroom exhaust... the ongoing saga... landev HVAC 9 01-05-2009 08:49 PM
Poor Attic Ventilation Mechanically Challenged Roofing 15 10-23-2008 10:05 PM
Powered Attic Fan question spup345 Roofing 9 06-30-2008 09:10 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
Roof/Attic Ventilation pramos67 Roofing 6 03-30-2007 01:27 PM
