Exterior Window Trim...PVC...Method...Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 07:45 PM   #1
Mr. Handy
Rewards Points: 12
We will be siding our house with vinyl and have decided to trim the existing windows with a PVC Brickmould that has a J-channel molded in. My question...how do I make the pieces to fit around the window? Do I measure the window, cut and glue the pieces together to form a frame and then attach to the house or attach one piece at a time and essentially create a frame on the window as I go? I think making a frame on the bench, oversizing it a bit is the way to go.
swiederin is offline   Reply With Quote
Old 07-13-2011, 08:23 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
thats how i would do it
Tom Struble is offline   Reply With Quote
Old 07-15-2011, 07:40 PM   #3
Mr. Handy
Rewards Points: 12
I plan to glue them together. Do i need to use screws at each corner or can I depend on the nailing fin of the j-channel to hold it all together once its attached to the house?
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
