Exterior Walls For A Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 01:11 AM   #1
Exterior Walls for a Shed
I am building a shed in my backyard, and i have everything down so far, except a simple yet confusing question... I choose to go with textured plywood for the exterior walls. The textured plywood happens to be particle board. What type of nails should i use to nail these baby's up? I went to local lowes and home depot, and their sheds also used textured plywood (osb plywood) and they just hold it up with staples. Should i use the same nails i used for my framing? finishing nails? or what should i do?
thanks!
nayr24 is offline   Reply With Quote
Old 07-03-2010, 09:22 AM   #2
Galvy nails for outside
I used finish nails on mine
Old 07-03-2010, 10:25 AM   #3
jlhaslip's Avatar
Rewards Points: 396
See if they have 1 3/4 " galvanized spiral nails. They hold pretty good for siding.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 07-03-2010, 03:27 PM   #4
Rewards Points: 1,910
Particle board is not plywood is not OSB. They are three different materials. I have never heard of particle board or osb sheet siding. I would use neither for the final exterior siding. Exterior plywood siding performs quite well if properly maintained. My house was built in 1976 with plywood siding and it is still in great shape.
Old 07-03-2010, 08:21 PM   #5
Registered User
Rewards Points: 4,936
Sounds like LP's SmartSide- osb: http://www.lpcorp.com/LP_Products/Wa...itional_Wood_/
http://www.lpcorp.com/smartside/how_is_it_made/
At the Depot: http://www.homedepot.com/Building-Ma...atalogId=10053
Don't use finish nails (no head) to stop the expansion. Or electro-coated galvanized nails (coating flakes off at installation from the gun driver, then rusts). Use hot-dipped galvanized unless on the Coast- use stainless steel there.
Plywood is best, as mentioned by Jogr: http://www.homedepot.com/Building-Ma...atalogId=10053
http://docs.google.com/viewer?a=v&q=...GKM_FjuKp8QM-g
Be safe, Gary
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
water run off in shed kathy k Building & Construction 4 08-09-2009 04:29 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
