Old 07-26-2007, 08:41 AM   #1
Exterior wall thickness???
I’m remodeling a house and had to remove the walls on the back porch which is considered part of the heated square foot since there is an air vent in the floor. Should the new walls be 2x4 or 2x6 – or does it matter?
Thanks,
Dave
diverdaveman is offline   Reply With Quote
Old 07-26-2007, 09:22 AM   #2
what do the codes for your area say
clasact is offline   Reply With Quote
Old 07-26-2007, 09:29 AM   #3
diverdaveman-----
Not sure what geographical area you are in, but in my opinion bigger is better. The 2x6 framing would allow for better/thicker insulation and will stand up to the elements better, i.e high winds. then you are covered either way, if code says 2x4 minimum then you are one step above, and if code says 2x6 minimum then you are still compliant.
DIY4EVER is offline   Reply With Quote
Old 07-26-2007, 09:47 AM   #4
Remember with 2x6 framing, you'll have recessed windows.
I would build with what size you took out.
Jeekinz is offline   Reply With Quote
Old 07-26-2007, 10:01 AM   #5
I would frame it out with 2x6's if you have the room. Additions have more walls exposed to the elements then the other rooms. Usually three sides, the ceiling and the floor are connected to unheated spaces. Heat loss is greater and quicker. I always frame additions with 2x6's and separately zone them.
Ron
Old 07-26-2007, 10:41 AM   #6
Thanks for all the info. I'll check my local building codes to see what "they" want.
Dave
Old 07-26-2007, 01:02 PM   #7
HandyMan Engineer
Ron
I follow the same practice.
sendres is offline   Reply With Quote
Old 07-27-2007, 01:25 PM   #8
Ron
the best recommendation that U can follow.
the heat loss is a lot higher heence the stuff!
HiFi is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Glass shower enclosure- What thickness should I use? showerneeded Remodeling 2 06-05-2007 08:28 AM
Driveway thickness??? mdlbldrmatt135 Building & Construction 3 12-01-2006 08:56 AM
Wall thickness RickT Carpentry 2 10-16-2006 10:23 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
