Exterior Wall With T1-11 Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 10:36 AM   #1
Rewards Points: 1,697
Exterior wall with T1-11 siding
We're planning to use T1-11 siding on our new house initially with a probable upgrade later on. Our thought was insulated walls with OSB sheathing, then Tyvek, then air gap, then the T1-11.
If we use the T1-11 as sheathing, wouldn't we have to put our vapor barrier on the inside of the insulated walls rather than outside?
For the air gap, I saw a picture online of a yellow plastic product for providing an airgap between cladding and housewrapped OSB: http://www.buildingscience.com/docum...ind-the-gap-eh.
Does anyone know what that is, where to find it, etc? I can't find anything other than this article that shows that product.
Any suggestions on our wall will be appreciated.
dalepres is offline   Reply With Quote
Old 03-28-2011, 10:11 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
http://www.benjaminobdyke.com/visito...ey/homeSlicker
where to put the vapor barrier depends on your location
Tom Struble is offline   Reply With Quote
Old 03-28-2011, 10:21 PM   #3
Registered User
Rewards Points: 526
"If we use the T1-11 as sheathing, wouldn't we have to put our vapor barrier on the inside of the insulated walls rather than outside?"----------------------------- Are you confusing a Vapor Barrier with a Water Resistive Barrier?
Where are you located?
Gary
Old 03-29-2011, 10:59 AM   #4
Isn't it T-111?
Anyway, where I live, the only vapor barrier that's necessary is the craft paper facing on the insulation. So a wall would look like this in section:
T-111 | Stud with batt insulation (facing towards interior) | drywall
In the future, when you want to upgrade the appearance of the house, you can put vapor permeable foam insulation on the T-111, and then Hardi plank, vinyl, stucco, or whatever you want. Or you can skip the foam and nail vinyl right to the T-111.
Although I really dislike T-111 on a house, it is the fastest, cheapest way to get an exterior that a bank will convert to permanent on, and it is relatively easy to upgrade later.
pyper is offline   Reply With Quote
Old 03-29-2011, 08:55 PM   #5
I'm in Oklahoma. We have very hot summers with A/C going inside and cold - below zero - winters.
GBR, I probably am mixing water barrier with vapor barrier - though most of the literature I read doesn't separate the two. I would appreciate any help in clearing that up. As far as my understanding goes now (which I admit is not fully developed) I am planning, from the inside out: 1/2" drywall, 2x6x10' wall with fiberglass insulation (not sure if it should be faced or not faced?), OSB sheathing, TYVEK housewrap, air gap, T1-11 siding, paint.
With Pyper's idea, if I could save a couple thousand dollars on sheathing, that would be great. But I don't want to risk the integrity of my wall - from a moisture perspective. I am definitely interested in where this discussion is going and learning how to get this right so please continue.
Regards,
Dale
Old 03-29-2011, 08:58 PM   #6
Originally Posted by pyper View Post
Isn't it T-111?
http://www.apawood.org/level_b.cfm?content=prd_sid_main
Old 04-02-2011, 08:51 PM   #7
Registered User
Rewards Points: 526
http://www.energysavers.gov/your_hom.../mytopic=11810
http://www.greenbuildingadvisor.com/...vapor-barriers
http://www.buildingscience.com/docum...ecommendations
Ask your B.D. on vapor barrier or retarder required; find your Zone on map or City below map; http://publicecodes.citation.com/ico...001_par001.htm
Zone requirements;http://publicecodes.citation.com/ico...001_par003.htm
Gary
Old 04-02-2011, 11:51 PM   #8
Rewards Points: 1,092
And if I may add, make sure someone reads you the code, or you read it. "Vapor retarder" is sometimes misinterpreted as "6 mil poly", which may be disastrous with air conditioning. And too, leave the fiberglass batts at the store. Rock wool, cellulose (batts or dense packed), cotton, or wool batts are better insulators (unless FG has gotten much more dense of late). Dense packed fiberglass does well, too. FG batts aren't that great.
hardie plank siding bob fortier Carpentry 4 05-31-2010 07:01 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
