Exterior Wall Sill Plate Not Sitting On Slab - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 06:55 AM   #16
Concrete & Masonry
Rewards Points: 620
Originally Posted by COLDIRON View Post
Wood already shrunk because it's been up for years , key words in your statement shrink a 1/64" , shrink means shrink.
Don't know how tight mix will be, don't assume installer will mix tight even if he does still 1/64"???
Sure if you take it out of context and remove the "wouldn't even shrink", it takes a new meaning...........
Think of it this way. When a 9' tall basement wall is poured, how much do you think it shrinks vertically? Not enough for crude measuring tools to detect. Why would such a small profile of concrete (1.5") be prone to such massive shrinkage? The answer is it won't.
jomama45 is offline   Reply With Quote
Old 09-30-2011, 07:02 AM   #17
kwikfishron's Avatar
Rewards Points: 818
Do they sell pressure treated shims???
They sell plastic ones. You can make them.
I see no reason to make a mud mess. Even if you did who cares if it shrinks 1/64.
How would that affect anything?
kwikfishron is offline   Reply With Quote
Tags
exterior wall , framing , sill replacement
Sill plate, rim joist replacement frkingz Building & Construction 0 05-11-2011 08:00 PM
Filling Gap between sill plate and slab DaveTile Carpentry 1 04-13-2011 03:52 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
new mudroom "Attaching sill plate to concrete patio" wildonewest Building & Construction 2 11-09-2010 12:10 AM
Keyed locks for windows, no sill plate, help! steveefer Carpentry 1 10-09-2007 10:13 AM
