Exterior Wall Rot - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 07:04 AM   #1
exterior wall rot
How do I determine if there is rot or moisture in the exterior wall of my home without ripping off the shingles?
Lajula is offline   Reply With Quote
Old 06-25-2012, 07:16 AM   #2
Rewards Points: 14,026
Is this a wall or a roof, reason I ask is your asking how to do it without removing the shingles, Shingles go on the roof not the wall.
What makes you think there may be rot?
It would be great if you posted a picture.
Old 06-25-2012, 07:21 AM   #3
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Signs to look for are discoloration to the interior baseboards, drywall or ceiling or a musty smell.
At the exterior look for discoloration or mold. Use a brad or skinny screwdriver and probe around in likely places. If it is soft and penetrates easily, you probably have some rot issues. The causes can be many. I would try doing these tests then post photos of what you find.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
The Following User Says Thank You to woody4249 For This Useful Post:
Lajula (06-25-2012)
Old 06-25-2012, 07:25 AM   #4
DIY staff
Rewards Points: 7,174
I've never done this---Many home inspectors and all Dryvit inspectors use a moisture meter,much like the testers used for wood---and test for elevated moisture from the inside of the house--
Lajula (06-25-2012)
Old 06-25-2012, 07:37 AM   #5
Thanks, do you know if I could rent a moisture meter and if there are different ones which one is most reliable?
Old 06-25-2012, 08:03 AM   #6
There not all that expencive.
http://www.amazon.com/b?ie=UTF8&node=553270
Lajula (06-25-2012)
Old 06-25-2012, 08:07 AM   #7
DIY staff
Sorry,but I do not know----A Google search for 'moisture meters' should help---
I'm a wood worker--so I use the type with pins--two little nails that poke into the wood--
this type might leave pin holes that you wouldn't like---there are non invasive testers but I can not vouch for their accuracy--the paint surface might be enough to insulate the electrodes and give you a false reading.
Wood moisture meters start at about $50---and go up to over $300--
A cheap one should be good enough for your purpose---look at Lowes--I read somewhere that they stock a pretty good cheap one---Mike---
Lajula (06-25-2012)
Old 06-25-2012, 08:11 AM   #8
DIY staff
Joe beat me to it---I have heard that the 'General' brand is good for the money--No experience personally--but accuracy is not that important --
Old 06-25-2012, 08:16 AM   #9
So why do you think there may be a moisture problum?
If any of the signs mentioned are showing then there's a moisture problum that needs to be addressed. No meter needed.
Old 06-25-2012, 08:30 AM   #10
Tom Struble's Avatar
Rewards Points: 2,002
one way i use when i first look at a house is to look at the foundation where it meets the house,if i see staining i know there is probably an issue
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Lajula (06-25-2012)
Old 06-25-2012, 09:56 AM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Start your moisture search from the inside. Use a moisture meter and a pencil to outline the high reading areas. The outline may sometimes help to pinpoint the moisture source like an "arrow".
If more needs to be determined, or, if you need to investigate further, start from the inside by removing an area, or a section of drywall (or plaster), and inspecting the insides of the wall bays or ceiling bays (the backside of the wall or roof sheathing can also be visible with water staining to lead you to the source of the leak).
Remember, its generally a lot easier (to do and to repair) and patch-up drywall, than it is to tear into your siding and wall sheathing, and perform repairs.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Lajula (06-26-2012)
