Exterior Wall Repair With Only A 8-10in Access - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 02:49 PM   #1
Unhappy
Exterior Wall Repair with only a 8-10in access
I have a 3 story 3 unit Frame Home built in 1881. The home next door is also a 3 unit 3 story brick building built in 1923. Here is my issue: My home only has an 8in to 10in gap in between the 3 unit next door. My home has the original wood siding (on this exterior wall only) that is rotted & causing moisture issues inside of the building. How do I repair or seal 3 story exterior wall with only an 8 - 10 in access??
willcountyland is offline   Reply With Quote
Old 08-24-2011, 03:05 PM   #2
Massive problem???? Do you know a tall, thin guy? Some-one smarter than I will be along to help soon.
jankencanada is offline   Reply With Quote
The Following User Says Thank You to jankencanada For This Useful Post:
willcountyland (08-24-2011)
Old 08-24-2011, 04:36 PM   #3
Rewards Points: 6,652
There really is not much you can do with that amount of access space.
Old 08-25-2011, 10:20 AM   #4
Rewards Points: 190
Perhaps you could get permission from your neighbor to put a roof over the 10" space attached to your house and your neighbors house.
zircon is offline   Reply With Quote
Old 08-25-2011, 11:25 AM   #5
Roof over 10in space
Zicon - THANK YOU. I have thought about that (or even enclosing the space & filling it with some type of expandable foam). I know this will solve the issue going forward but how do I remediate the existing moisture issue? any ideas?
Old 08-25-2011, 11:43 AM   #6
Only way is to tear down your house or the other. Sounds like they built or moved one of the structures for a zero clearance on the lot line.
Old 08-25-2011, 11:47 AM   #7
Tear Down the House
Greg - Yes, that is exactly what I thought. I don't think it is possible to remove the entire wall from the interior to rebuild the exterior. WAY OUT of my financial league.
Old 08-25-2011, 01:06 PM   #8
Rewards Points: 190
If it were roofed over to prevent new rain from getting between the buildings, and there is good air circulation between the buildings, I think the wall would dry out by itself.
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Installing and attic access and a "What is this?" cbaileyau General DIY Discussions 16 12-19-2009 02:54 PM
Delta 10in table saw repair GillesLam Building & Construction 3 03-21-2009 04:19 PM
Finishing off access door panel TanMan Building & Construction 12 02-05-2009 05:59 PM
