Exterior Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 02:13 PM   #1
Hey Everyone. First thanks for all the help with my bathroom remodel. You all were very helpful and the bath looks amazing!!
So I am back for round too and this time it is for my wall insulation on all of my exterior walls. The plan is to, over the next couple/three years, to replace all of my single pane windows with some nice double pane, double hung Andersens and also to replace the siding (not sure which yet though with the siding). However, before I truly get to that, simply becuase of price, I was wondering what the best way to insulate my exterior walls would be??
I have a 1950 story and a half style home in Minneapolis MN. I have not taken a wall down to see what is even currently there, but after living in the home last winter, I would venture a guess of not much to nothing at all. It was extremely cold last winter, thus my new post. I also can hear a lot of the exterior noises, which also leads me to believe that there isn't a lot there.
I would like to avoid removing all of the interior walls because they are all nicely finished plaster walls. The siding is cedar shake that will need to be replaced at some point (within 5 years), but don't have the funds currently to do so.
So, are there any efficient ways of insulating my home without tearing off the siding or interior walls?? I have heard of blown in insulation where they drill a hole at the top and bottom between each stud, but don't really know much about it.
Any guidance as to where I should begin would be wonderful. Also, is this something that I should be doing or should I just hire it out to a company? If it should be hired out, what should I expect to pay someone to complete this?
Thanks in advance for all the help.
Dutchman80 is offline   Reply With Quote
Old 08-06-2010, 09:28 PM   #2
Registered User
Rewards Points: 5,514
http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
No vapor barrier required: http://books.google.com/books?ei=Vu8...Books&as_brr=3
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
