Exterior Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 08:52 AM   #1
exterior wall insulation
should exterior walls be covered with plastic over insulation?
JimmyQ42 is offline   Reply With Quote
Old 11-19-2011, 11:43 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
is this on the inside of the house or outside. depending on the region it can vary.. in warm climates a vapor barrier must go on the outside of the framing, where as in colder climates house wrap goes on teh outside and plastic goes on the warm side (inside) of hte wall
woodworkbykirk is offline   Reply With Quote
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 05:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
