Exterior Wall Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 02:24 PM   #1
Exterior wall construction
Is it ok to not have plywood sheathing on an exterior wall? My house only has rigid foam board and siding
NickS is offline   Reply With Quote
Old 02-05-2012, 02:57 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
People do it that way (but they put special bracing in the walls), but it's better to have the osb or plywood solid sheeting.
It's even required in most places nowadays.
titanoman is offline   Reply With Quote
Old 02-05-2012, 03:29 PM   #3
Framing Contractor
Millions of houses are built with plywood sheathing. That's how most of them are done. Back in the early 80's we used foam board on some condos, but we had to install 1x4 let-in bracing and each corner had to have a full sheet of plywood on it. That was code back then. Now for me it's all plywood.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (02-05-2012)
Old 02-05-2012, 06:02 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
ive built a few home houses, and many fully sheathed houses. personally i hate the foam ones.. even with let in bracing they still move in heavy winds from hurricanes. i also dont like how someone can simply remove a few peices of siding and cut into the house with a knife if they really want to get in
more recently though with my region becoming hit by hurricanes more and more, the foam house practice is a thing of the past
woodworkbykirk is online now   Reply With Quote
Old 02-05-2012, 06:38 PM   #5
Rewards Points: 13,748
Do you notice creaking and popping noises when the wind blows, notice more then normal screw or nail pops in the drywall and cracks in the corners near the doors and windows? Caused from from not enough shear streingth from no sheathing.
Old 02-05-2012, 07:02 PM   #6
What would be some methods of correcting or strengthening these walls without pulling siding off of the house, if this is even possible? Thanks in advance for any advice
Old 02-05-2012, 07:17 PM   #7
Disabled wood vet
titanoman's Avatar
I agree with Wwbk about security.
Why the concern? There's bracing in the walls.
Old 02-05-2012, 07:22 PM   #8
Rewards Points: 150
Sheathed walls make for a stronger more rigid building. Your house with foam board, and I assume some let-in bracing or sheathed corners, may be adequate for your area. Fully sheathed buildings are typically required in seismic zones and high wind regions, particularly high wind where wind borne debris is a danger. I don't see an easy way to remedy your situation, I suggest you see an architect or professional engineer for a means to strengthen the house, they may be able to come up with a method that is readily achievable.
TheCamper is offline   Reply With Quote
Old 02-05-2012, 07:33 PM   #9
The only way I can think of it to remove all the siding, which would mean the windows and doors would also have to come out unless they used plywood or OSB under the nailing fins.
Not a small job or cheap to do. What's your concerns with the way it is now?
Old 02-06-2012, 10:59 AM   #10
Registered User
Rewards Points: 5,516
"What would be some methods of correcting or strengthening these walls without pulling siding off of the house, if this is even possible?"------------------ if any easier, you could add shear bracing from the inside; diagonal blocking, diagonal straps- flat, "T", "L", or interior sheathing with OSB or plywood. Some are much stronger than others: http://bct.nrc.umass.edu/index.php/p...n-the-outside/
http://www.strongtie.com/products/co...c-twb-rcwb.asp
Depending on where you live and how secure you want to feel for the amount of bracing required. Check the "high wind" areas and the "seismic zones" on the maps here: http://publicecodes.citation.com/ico...001_par004.htm
Here is the 90 mph wind safe house shear requirements: http://www.awc.org/pdf/WFCM_90-B-Guide.pdf
Info on truss bracing, if needed: http://www.xpsa.com/tech/FSC%20Braci....2%20FINAL.pdf
Gary
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-04-2011 11:32 PM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 06:05 PM
Contractor pre construction retainer scorpious Off Topic 3 07-29-2010 11:32 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-26-2008 11:05 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
