Exterior Trim Nail Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 05:45 PM   #1
Rewards Points: 358
exterior trim nail size?
Putting up 1x4 trim on the outside of the house what nail size can I use?? Think I want to use a nail gun to make it quick. I have an 18 gauge nailer that fits up to 2" nails, I googled if it would work and some say yes, other say no?? I dont want to spend a fortune on a nail gun as this is probably the only time I would use it, so I think I will probably just get something cheap from Harbor Freight.
cbzdel is offline   Reply With Quote
Old 04-28-2011, 06:12 PM   #2
Rewards Points: 2,240
2 inch nails would probably, be OK - galvanized!!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-28-2011, 06:18 PM   #3
remodeling pro
For exterior trim exposed to the elements, I only use 15 ga, with ss nails. Work that is protected, such as under a porch, is ok with 16 ga "galvanized".
After a couple of years in an exposed setting, these 16 ga are just about completed corroded away.
Of course I am highly anal retentive .
troubleseeker is offline   Reply With Quote
Old 04-28-2011, 06:51 PM   #4
Rewards Points: 358
I dont want to sound totally stupid, but if I plan on caulking over them and then painting over that, does that still consider them as exposed?
Old 04-28-2011, 07:50 PM   #5
kwikfishron's Avatar
Rewards Points: 824
7d SS ring shank siding nails. You want a head on your siding/trim nails. Why would you calk over them?
kwikfishron is online now   Reply With Quote
Old 04-28-2011, 08:45 PM   #6
Rewards Points: 358
everything is caulked over now, i figured thats just how it was done
Sounds like I need a new nail gun then..
Old 04-28-2011, 09:14 PM   #7
Rewards Points: 824
I never gun nail siding trim or exposed nailed lap siding.
Old 04-28-2011, 09:50 PM   #8
Rewards Points: 358
you know I think you talked me out of it haha! I only have to trim around 3 windows and 1 door and 6 corners, why I am being so lazy haha!
Old 04-28-2011, 10:17 PM   #9
use 8 Galvanized. Do you have a hammer?
knucklehead is offline   Reply With Quote
Nail size Lazer Carpentry 4 04-12-2011 03:06 PM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
power-actuated nail size for sole plates amakarevic Building & Construction 4 06-03-2008 01:12 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 11:24 AM
