Exterior Stoop / Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 03:55 PM   #1
I've been digging through the code and I can't find an answer to this question. Can my exterior stoops/stairs be made from wood?
My house is in California and I'm adding two exterior doors to the rear of my house. The house is one-story and built on a raised floor with concrete footings (no slab). I have been told that exterior stoops/stairs are required for my final inspection. The stoops would be 2-3 steps at most including the landing. Does anyone know where I can find the exact code information for my exits?
My contractor insists they have to be concrete but he has been wrong about several things so I'd like verification from the code if possible. If they can be made from wood, I'm assuming there are requirements to discourage rotting so any information about that would be great too.
Thanks in advance.
joside is offline   Reply With Quote
Old 04-14-2010, 04:25 PM   #2
kwikfishron's Avatar
Rewards Points: 772
I sure would think so.
A simple call to your local building department should answer your question. Call “early” and ask to speak to a inspector for a simple question. If you call early that’s your best chance to find someone at their desk and before they head out to the field.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
joside (04-16-2010)
Old 04-16-2010, 01:07 PM   #3
Just to follow up for anyone who might care, I contacted an inspector and they told me wood is fine as long as anything within 18" of the ground is pressure treated wood. A landing is required for final inspection (so people won't fall out the door) but steps aren't specified and are up to the individual inspector. Thanks for the advice.
Old 04-16-2010, 01:37 PM   #4
Rewards Points: 772
Maybe it's time to re-think your choice of contractors.
Willie T (04-16-2010)
Tags
exit , exterior landing , exterior stairs , exterior stoop
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Exterior Stairs to Coach House Need to be Repaired/Replaced. Help Appreciated! 2031pratt Carpentry 9 04-07-2010 02:43 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 07:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-29-2009 11:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
