Exterior Steel Door Is Too Narrow - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 11:20 AM   #1
Knucklez's Avatar
Rewards Points: 932
Exterior steel Door is too narrow
i am in the process of ordering a new front door, exterior, steel. the exact measurement of the existing door is 33 7/8" wide but the new door comes in 33 6/8" wide. That means the gap will be 1/8" plus whatever was already there.
is this going to be a problem? if so, what are the solutions?
unfortunately the door does not come in size 34" wide because then i could just belt sand the wooden door jamb...
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 05-25-2011, 12:55 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I would get a new prehung door and replace the whole frame and door as a unit.
Coastal South Carolina
Old 05-25-2011, 02:20 PM   #3
Rewards Points: 1,010
You'll be fine
Anti-wingnut is offline   Reply With Quote
Old 05-25-2011, 04:54 PM   #4
Knucklez's Avatar
Rewards Points: 932
agreed with the pre-hung, but it is not an option in my house. the old trim is thick and huge with monster nails.. it would be destroyed trying to take it off.
thx wing-nut. i guess i was just worried that the metal door knob tab would not latch properly due to the gap and that the air seal would be poor. but you think it will be fine?
Old 05-25-2011, 05:00 PM   #5
You're talking about increasing the reveal 1/16" per side. Unless this door is on a submarine, aircraft or space shuttle, you'll be just fine
Old 05-25-2011, 05:06 PM   #6
A "Handy Husband"
rjniles's Avatar
If you can not use a pre-hung and need to replace just the door, here is a idea. I have done this using a fiberglass door.
Glue up some composite lumber to get 1.75" thickness, cut a slice about a 1/4 thick. Fill the hinge mortices on the door and glue the strip to the hinge side of the door. Use a power planer to trim the door to the needed width, re-mortice the hinges and hang the door.
Old 05-25-2011, 05:09 PM   #7
A "Handy Husband"
rjniles's Avatar
The additional reveal would all be on the latch side and an additional 1/8 " is too much.
Old 05-25-2011, 05:13 PM   #8
You throw or shim the hinges a teeny bit.
It'll work. Believe me. I've put in literally thousands of doors
Old 05-25-2011, 06:14 PM   #9
Rewards Points: 282
if you cant figure out why this isnt true (you can make it wherever you want it), then you probabaly dont have the skill anyway to hang it within 1/8" of plumb so whats the difference.
jcrack_corn is offline   Reply With Quote
Old 05-26-2011, 11:24 AM   #10
Knucklez's Avatar
Rewards Points: 932
hmm... now i'm cnofused
if i put the hinges on the door and then install the hinges to the frame in the exact same spot as original door.. then the other side of the door, where the latching tab is, would have a gap of 1/8" + whatever was originall there (1/16" by the looks of it). the gap exists only on one side of the door when installed in this way. there should be some gap so the door can close, but is 3/16" too much?
sounds like this is NOT ok .. but the solution is to just shim out the hinges a bit? ??
Knucklez
Old 05-27-2011, 12:11 PM   #11
1/8" is not a big deal. Certainly not enough to warrant rippling long strip to laminate to your door, and then mortising new hinge pockets.
Place the new door in the frame. If it works correctly, go on with life. If there is some issue, which will undoubtedly be minor, you can shim the hinges.
This is typically done with narrow strips of cardboard. To decrease the reveal on the strike side, place this shim under the hinge leaf as close to the hinge barrel as possible
Old 05-27-2011, 05:24 PM   #12
Knucklez's Avatar
Rewards Points: 932
sounds good wingnut, thanks for the advice!
where to find narrow plank width laminate pamelajosmith Flooring 2 03-13-2011 11:58 PM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Too ambitious? Narrow cabinet or shelf a new DIY-er Carpentry 9 02-04-2010 11:06 AM
Cutting Narrow Tile Pieces MrBill_DIY Remodeling 2 08-17-2008 12:33 AM
narrow hallway txbostont Building & Construction 1 11-01-2007 04:17 PM
