Exterior Stair Landing Tread Size Min/max? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 07:30 AM   #16
Rewards Points: 2,240
"jackwashere"
Not knowing where you are -
I think it would be a good idea, to make sure the footing/grade-beam
at the bottom of the stairs - extends down, below the frost line -
also, the one against the house.
Just an opinion.
rossfingal
rossfingal is offline   Reply With Quote
Old 01-06-2012, 01:06 PM   #17
Rewards Points: 248
There is no "one against the house". The architect/engineer just threw some plans for stairs from another project into my project. Check out the picture, attached. The site is in a flood zone so they made me build the house on top of a 4 foot above grade 2 foot below grade (6 foot total) structure. That's what the stairs are for, to get from ground/grade level to the house. The foundations 2 feet underground are 4 feet wide. So the 1 foot wide/deep foundations called for in the stairs plan would be situated on top of 4 foot wide foundations. It would be a case of tiny foundations resting above huge buried foundations. That's ridiculous! What I did instead was I placed #4 and #5 rebar 6" o.c. for the stairs about 16 inches deep into the main slab. The main slab is 8" thick. The wall supporting the slab is 1 foot thick. That rebar is not going anywhere! It will hold the stairs up very well. This whole thing is built like a tank, a bunker.
I just spoke with the inspector this morning. All he cares about is how the foundations will look. After that I can build whatever structure I want for stairs. I just might try to swing my version of the stairs project after all.
As for frost line. The plans call for 12" foundations. When we dig water line trenches we make them 18". The official maps bundle all of California into one zone, and claim our frost line is 5". You have the snowed in Sierra mountains and low land areas down south near the beach where it never gets too cold. Yet on the official maps that show frost line all of California is one zone.
Exterior stair landing tread size min/max?-pour5.jpg
jackwashere is offline   Reply With Quote
Old 01-06-2012, 02:15 PM   #18
Concrete & Masonry
Rewards Points: 620
As long as bottom tread of the steps is sitting of solid undisturbed soil, the first drawing will be just fine with a 6" slab. Make sure you allow at least 4" under each riser form so the rebar has decent coverage. You'll also want to fill in the majority of the center "hump" with gravel/aggregate/broken block pieces/stones/etc... so you don't need to waste the additional concrete AND you relieve a little pressure on your forms.
jomama45 is online now   Reply With Quote
Stair landing construction rkoutz Carpentry 2 04-19-2011 10:16 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Need assistance installing brazilian cherry stairway BobS0327 Carpentry 8 09-07-2010 10:30 AM
Plenum Min/Max size? jjrbus HVAC 6 06-26-2010 06:42 AM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 08:52 PM
