Exterior Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 10:18 PM   #1
Rewards Points: 37
Exterior Sheathing
Hi, I am replacing the sheathing, windows (2), and siding on the front of my house. It is a small area about 8' high and 12' long. Pretty sure I have the windows and siding dialed in. But, for sheathing I am using 23/32 T&G OSB and installing it vertically. I got it at Lowes and the info sticker said it was for roofing, siding, and sub floors. On the the actual OSB sheet it only references sub floors. The edges are painted grey (does that mean it is suited for a particular purpose?) I think the 23/32 is a bit thicker than a standard application for sheathing but it works better for my arrangement. Is there any problem with what I am doing in terms of the sheathing?
RodBarney is offline   Reply With Quote
Old 06-19-2012, 10:40 PM   #2
Maryland
23/32 T&G OSB is an underlayment/subfloor product. 7/16 OSB is typically used for sheathing in my neck of the woods.
What's installed on the house right now? Why are you having to replace the sheathing in the first place?
Pittsville is offline   Reply With Quote
Old 06-19-2012, 10:44 PM   #3
Framing Contractor
Rewards Points: 98
Your fine.
sixeightten is online now   Reply With Quote
Old 06-19-2012, 10:49 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
One problem I can think of is the window jamb width will be affected 1/4" using the 3/4 sheathing. you might need jamb extensions, regular sheathing is 1/2". you can extend either the inside jamb or outside. Also,you might want to check the manufacturers' website to determine how to install that type of OSB as it is mostly used for sub flooring and is nailed/screwed on the horizontal not the vertical. it may need to be installed horizontally on the sheathing just as it would lay across floor joists on a floor. when installing,the tongue and groove works better perpendicular to framing also in general.
hand drive is offline   Reply With Quote
Old 06-19-2012, 11:07 PM   #5
Rewards Points: 37
Old painted plywood from the seventies. Needs to replaced because of wear and aesthetics.
Old 06-19-2012, 11:10 PM   #6
Rewards Points: 37
10-4. But in my case the thickness will benefit the window installation.
Yeah that was one of my main concerns, if I was installing it in the proper direction..
Old 06-20-2012, 12:59 AM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Is it rated for exterior applications like what you want to do with it?
Even though it will be covered by siding and presumably some kind of water resistant barrier, it should be exterior rated.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Gary in WA (06-20-2012)
Old 06-20-2012, 01:08 AM   #8
Registered User
Rewards Points: 4,912
Sounds like "Sturdy-I-floor", (Exposure1); http://www.apawood.org/apacad/images...specs/Y310.pdf
As Andy said: http://www.apawood.org/pablog/index....f-plywood#more
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
RodBarney (06-20-2012)
Old 06-20-2012, 11:09 AM   #9
Rewards Points: 37
It is exposure 1. Yes it will be covered with 60 min. building paper and siding. I thought the combo of exposure 1, barrier, and siding would suffice..
Should I paint the OSB before I put the paper on, would that do me any favors?
Thanks.
