Exterior Rigid Foam For Interior Use? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 09:53 PM   #1
Exterior Rigid Foam for Interior Use?
What's the difference here? Aside from the price... It looks the same. Can I use "CodeBoard" on the interior basement wall? It would be covered by a stud wall, batt insulation, and drywall.
http://www.homedepot.ca/webapp/wcs/s...chLevel=level1
If the link doesn't work, search the following numbers on homedepot.ca:
CodeBoard (exterior): 905953
Celfort (interior): 905948
Reilley is offline   Reply With Quote
Old 10-27-2008, 10:18 PM   #2
What can I find here?
Winchester's Avatar
Rewards Points: 150
To be honest, I don't really see a difference either. I noticed the other is only 24"....maybe you're paying to have something cut perfectly to fit in between a 24" OC stud cavity? I also think that a 1" foamboard averages about a 5 R-value. Have you considered a 2" foamboard? I'm only asking because it was suggested to me by our energy auditor earlier this here.
Go with the cheaper stuff IMO. Are you going to use and adhesive to mount to the basement walls? If I remember correctly I think PL300 was suggested?? I know I've mentioned it here before...
Best of luck and keep us in the know.
Winchester is offline   Reply With Quote
Old 10-27-2008, 10:50 PM   #3
Thanks Winchester. The reason I'm going with 1" is because I'm going to also use 6" fibreglass batt. This will give me R-25 and a heafty grant from the government.
I was reading up on adhesive tonight, and came to the same conclusion of using PL300 or PL Premium.
Old 10-28-2008, 03:27 AM   #4
Lansing's Avatar
Yes you should be able to do that...Not a bad price either...Good luck on the grant and the warmer, cheaper to heat home you will have there...Good plan...
When the time comes for you to leave this world
the only thing you get to keep is what you gave away...
Lansing
Lansing is offline   Reply With Quote
Old 10-28-2008, 08:59 AM   #5
Registered User
Termite's Avatar
Nothing wrong with using foamboard in a home. Just remember that it always has to have an ignition barrier (such as drywall, plywood, etc) over it, and cannot be left exposed in accessible areas such as basements and attics.
Old 10-28-2008, 06:13 PM   #6
Winchester's Avatar
Rewards Points: 150
I would then assume that you are going to use 2x6 studs?? Would it be cheaper to spend more money on the foamboard and less for 2x4 studs? Just a thought to consider.
Or perhaps you had the other post I read the other day and you're leaving 2" behind the studs and the foamboard?
Old 10-28-2008, 10:13 PM   #7
Yep that was me.
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 11:07 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 08:12 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
why use paint brushes instead of foam brushes? joeyboy Painting 18 09-23-2007 06:52 PM
