Old 10-25-2012, 10:55 PM   #1
exterior plywood Marine
I am covering an exterior building with marine plywood and want to make the seams disappear. What can I use to tape the joints
billymcgarry is offline   Reply With Quote
Old 10-26-2012, 10:28 AM   #2
#1 Why the maraine grade, unless your getting it for free it's one very expencive way to go with nothing to gain.
There is no magic tape to cover the seams.
Is it at least Tonged and groved or have an over lap to air seal it?
Old 10-27-2012, 07:18 AM   #3
Yes, you should use timber cladding, which will have grooved joints.
Gissle is offline   Reply With Quote
Old 10-27-2012, 10:55 AM   #4
sdsester's Avatar
Why not some nice redwood or cedar siding for just such purposes? I assume the building is structurally sound and you are just using the plywood as a veneer?
sdsester is offline   Reply With Quote
Old 10-27-2012, 11:55 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
the only reason i can see using marine grade is if your directly on the water. salt water specifically. if your worried about rot from excess moisture id use the wood framing blueskin if your going over it. i believe its blueskin xp or something, it still breathes so you dont get dryrot
woodworkbykirk is online now   Reply With Quote
Old 10-27-2012, 12:17 PM   #6
Bombastic Idiot
notmrjohn's Avatar
Why are you using marine grade?
Caulk the seams, if tongue and groove fill groove with caulk slide together make sure its firmly seated, squeezing out most of caulk. If not T&G caulk seams, cover with a batten. A 1X2, 1X3 or 1X4 over the seam. You can cover T&G with batten if you want. I assume you are using marine grade for a durability purpose? Best use pressure treated, cedar, or redwood for battens.
Major difference between marine and exterior grades is surface appearance and size and number of gaps or voids in interior plys. The glues are usually identical.
Above marine grade are sign board grades. No voids allowed, no knots, sanded extra smooth, superior resin glues. Stuff lasts forever, it ought to considering price and you have to get it from sign makers supply.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 10-27-2012, 12:39 PM   #7
Bombastic Idiot
notmrjohn's Avatar
I'm back already. "seams disappear", you want the seams to be non-visible rather than seal them? Treat it as if it were dry wall only using fiber-glass strips instead of tape and mud. You'll have to sand a taper along the edges of plywood just as drywall has. Then embed "tape" in resin. Plywood will expand and contract some, final resin gel coat may crack. Might need a deeper wider taper, narrow strip of glass with two or more strips over it, each wider than one below. Go as wide as you can, as many layers as you can,without building up a bulge or having edge of tape over untapered plywood. Feather out edges of each coat of resin. Feather sand final edges of resin and tape, a final coat of bondo or other body filler feathered out. It would probably bee good idea to oils base prime and paint all surfaces and edges of ply before fiber glass, to reduce expansion and contraction, Then lightly sand areas to be fiber glassed.
Old 10-27-2012, 10:45 PM   #8
Moderator
Not as siding; http://www.apawood.org/pablog/index....or-siding#more
Leave the joints open for expansion to prevent buckling; http://www.apawood.org/pablog/index....-buckling#more
Gary
PS. welcome to the forums!
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
woodworkbykirk (10-28-2012)
Marine Enamel vs House Enamel BigJim Painting 2 05-19-2012 06:07 PM
Marine week 2011 (St. Louis) STL B. Off Topic 6 06-27-2011 09:18 PM
marine stereo wiring burt dow Electrical 4 05-25-2011 12:16 PM
Marine Varnish?? Geaux4Tigers Painting 7 11-15-2010 10:13 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 02:11 PM
