-   -   exterior of a mobile home (http://www.diychatroom.com/f19/exterior-mobile-home-172423/)
Mark Harvey 02-19-2013 06:38 PM
I have been asked to quote on re-siding and a new roof for an older mobile home. In our climate Cebtral Alberta), it makes sense to add ridgid insulation if a re-siding job is being done. Question one, should the old skin/siding be removed or just go over top? Number two, I would plan on strapping as well as the insulation, what is the suggested thickness for insulation. Third, the client wants to add a peaked roof. I have heard to two ways to do this. One is to go on top of the existing roof with taylor made trusses and the second method is to remove the old roof (or open it up) and use regular trusses. The second is so that you can see any damage, mould, water stains etc.,
All advice is welcome, especially from those who have actually done this type of work.
Thanks.
rrolleston 02-19-2013 08:10 PM
I would remove the siding so you can see what is under there and make sure you will not hit any wires. Our home had a peaked roof added with trusses and it's nice to have a crawl space up there they filled it with insulation but you can get up there to run wires venting or whatever is needed.
