Exterior Load Bearing Wall Parallel To Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2008, 03:00 PM   #1
Exterior Load Bearing Wall Parallel to Joists
When an exterior load bearing wall is to be built parallel to the floor joist, and the band joist is supported by a cmu wall, do you still double the joist at that location?
Thanks,
Sam
samjack is offline   Reply With Quote
Old 08-02-2008, 05:08 PM   #2
Big Bob is offline   Reply With Quote
Old 08-02-2008, 06:11 PM   #3
Thanks Bob - that's the way I remembered it, but wanted to verify. Heck, the last time I did this we didn't have black diamonds every 19.2" on our tapes.
-Sam
Old 08-02-2008, 07:54 PM   #4
Framing Contractor
Thanks,
Sam
Sam,
The answer is no. I'm a Framing Contractor and I've never once doubled the box. Why would you need to? Even with a 2x6 wall, you still don't have to double the box. Unless for some strange reason it's code where your from, but I doubt it.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-02-2008, 08:37 PM   #5
Gents:
I had to dig around a bit to find my notes re current local requirements:
Load-bearing walls parallel to floor joists (and beams) shall be continuously and directly supported by a subordinate bearing structure as in double joists, beams, girders, or other load-bearing wall.
It makes no exclusion for interior or exterior walls, but if I'm reading this correctly then the foundation wall is the "other load-bearing wall".
As a historical reference, a note in my 1976 residential construction manual states: "in new construction the outside joist shall be doubled."
Thanks again.
Sam
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
