-   -   Exterior Load Bearing Wall Parallel to Joists (http://www.diychatroom.com/f19/exterior-load-bearing-wall-parallel-joists-24643/)
samjack 08-02-2008 03:00 PM
When an exterior load bearing wall is to be built parallel to the floor joist, and the band joist is supported by a cmu wall, do you still double the joist at that location?
Thanks,
Sam
Big Bob 08-02-2008 05:08 PM
:yes:
samjack 08-02-2008 06:11 PM
Thanks Bob - that's the way I remembered it, but wanted to verify. Heck, the last time I did this we didn't have black diamonds every 19.2" on our tapes.
-Sam
Joe Carola 08-02-2008 07:54 PM
Thanks,
Sam
Sam,
The answer is no. I'm a Framing Contractor and I've never once doubled the box. Why would you need to? Even with a 2x6 wall, you still don't have to double the box. Unless for some strange reason it's code where your from, but I doubt it.
samjack 08-02-2008 08:37 PM
Gents:
I had to dig around a bit to find my notes re current local requirements:
Load-bearing walls parallel to floor joists (and beams) shall be continuously and directly supported by a subordinate bearing structure as in double joists, beams, girders, or other load-bearing wall.
It makes no exclusion for interior or exterior walls, but if I'm reading this correctly then the foundation wall is the "other load-bearing wall".
As a historical reference, a note in my 1976 residential construction manual states: "in new construction the outside joist shall be doubled."
Thanks again.
Sam
