Exterior Layer Sequence - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 12:42 PM   #1
Rewards Points: 280
What is the correct sequence for the exterior?
Sheathing, house wrap, foam board or sheathing, foam board, house wrap?
Thanks.
Earnie is offline   Reply With Quote
Old 10-30-2012, 12:46 PM   #2
Rewards Points: 13,750
May want to share what it is your trying to do.
Is this new constrution, going over old siding?
Also make sure you have your location in your profile.
Old 10-30-2012, 01:27 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
what type of foam and what type of siding are you using
woodworkbykirk is offline   Reply With Quote
Old 10-30-2012, 02:27 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
And where do you live? What you do in GA is a lot different than say CA.
Old 10-30-2012, 03:39 PM   #5
Rewards Points: 280
Replacing windows which will require removing the existing vinyl siding. Not sure just yet what is under the siding. I suspect only 1/4" fan-foam board over the sheathing then the siding. I want to add a house wrap but need to be sure of the installation sequence.
Yes, I know, it would help to install a greater R-value foam board.
I suspect the house wrap would go over the foam board since the foam board would be harder to seal.
N.C.
Old 10-30-2012, 03:52 PM   #6
Now go back and let us know how the whole wall system was done.
Not a great plan to have foam on the outside in most cases. That would be a vaper barrier that needs to be on the inside not the outside. Double vaper barriers can lead to moisture build up inside the wall.
Old 10-30-2012, 04:03 PM   #7
Rewards Points: 280
Interior to Exterior Wall Assembly
Interior: 1x4 Oak Tongue and Groove
2x6 Studs
R19 Fiberglass (will know for sure when interior T&G is removed)
Exterior: 1x6 pine T&G
1/4" foam board (flat nailing surface for vinyl siding)
Nailite Rough Sawn Cedar Shake Vinyl Siding
Old 10-31-2012, 05:32 AM   #8
Rewards Points: 280
I have my answer.
http://www2.dupont.com/Tyvek_Weather...h_Bulletin.pdf
Wiring Lights to turn on in Sequence with a delay Campaign1 Electrical 4 01-27-2016 07:07 PM
Proper ignition/blower sequence in older gas furnace? frascati HVAC 39 03-06-2012 11:35 AM
Finishing my basement - project sequence? maljeff Remodeling 3 09-27-2010 09:23 PM
Reset Sequence for AO Smith ProMax? howie61 Plumbing 1 03-17-2010 11:03 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
