Exterior Insulation Foam Board Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 10:46 PM   #1
Question
exterior insulation foam board sheathing
On the house I am planning to build I planned to put an inch of insulated foam board sheathing on the exterior of the framing and fill the cavities between the studs with fiberglass insulation. My architect said it was a mistake. He said it would be too expensive to bring the foam boards into a rural area and they would be damaged in construction, but I have seem this recomended from many scources. Any opinions on this.
firemem is offline   Reply With Quote
Old 03-19-2010, 11:35 PM   #2
Where are you located ?
Old 03-20-2010, 05:35 AM   #3
Remodeling Contractor
It is an advisable plan. PM me if you want more details on this approach. I can send you docs on how and why to do it. The main reason is to bring the wall's net R-Value up. The studs if not covered by your foam insulation work as a thermal bridge bringing the overall effect of insulation down. this is the only way to address this if you are working on an existing house. But other methods such as staggered studs are more commonly used if you are planning a new wall.
Old 04-28-2010, 07:37 AM   #4
If not to much trouble some docs ould be great
firemen is offline   Reply With Quote
Old 04-28-2010, 08:17 AM   #5
pm me with your email address and I can send you something
Old 04-29-2010, 07:51 PM   #6
docs
Thanks for the help. The email is andersonretirement@gmail.com
rigid foam board and height ctkeebler Building & Construction 4 01-09-2010 03:42 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 05:05 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 05:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
