-   -   exterior insulation foam board sheathing (http://www.diychatroom.com/f19/exterior-insulation-foam-board-sheathing-67191/)
firemem 03-19-2010 09:46 PM
On the house I am planning to build I planned to put an inch of insulated foam board sheathing on the exterior of the framing and fill the cavities between the studs with fiberglass insulation. My architect said it was a mistake. He said it would be too expensive to bring the foam boards into a rural area and they would be damaged in construction, but I have seem this recomended from many scources. Any opinions on this.
Scuba_Dave 03-19-2010 10:35 PM
Where are you located ?
Bob Mariani 03-20-2010 04:35 AM
It is an advisable plan. PM me if you want more details on this approach. I can send you docs on how and why to do it. The main reason is to bring the wall's net R-Value up. The studs if not covered by your foam insulation work as a thermal bridge bringing the overall effect of insulation down. this is the only way to address this if you are working on an existing house. But other methods such as staggered studs are more commonly used if you are planning a new wall.
firemen 04-28-2010 06:37 AM
If not to much trouble some docs ould be great
Bob Mariani 04-28-2010 07:17 AM
pm me with your email address and I can send you something
firemen 04-29-2010 06:51 PM
docs
Thanks for the help. The email is andersonretirement@gmail.com
