Exterior Insulation Board Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 07:24 PM   #1
Mr. Handy
Rewards Points: 16
I am residing my 110 year old home with vinyl siding. I have torn off the old wood siding and felt paper to get down to the shiplap. I intend to use 1/2" foam board, and cover with housewrap prior to the new siding. Should I caulk around the foamboard where it meets windows etc?
swiederin is offline   Reply With Quote
Old 05-26-2011, 08:26 PM   #2
Custom Home Builder
I always back caulk prior to installing j-channel.
Wouldn't hurt to tape where the house wrap meets the windows and doors.
Won't matter much though, if your windows and doors are s**t.
thomasjmarino is offline   Reply With Quote
Old 05-27-2011, 12:30 PM   #3
Rewards Points: 1,092
If possible, put some insulation out there while you are at it. At least an inch. A rain screen is always a good idea, too.
GMP075-3, Bad Board?? RaySuave HVAC 2 12-12-2011 10:02 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
rigid foam board and height ctkeebler Building & Construction 4 01-09-2010 02:42 PM
particle board question??? Axhammer Flooring 27 01-04-2010 07:08 PM
