Exterior Insulation Board Opinion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 09:58 AM   #1
Mr. Handy
Rewards Points: 16
I am going to side my house with vinyl siding. I will be tearing the wood siding off and the plan is to use insulation board covered by housewrap. Which insulation board should I use? A foil faced product or unfaced product like blue-board? I will be using a 1/2" thick product either way.
swiederin is offline   Reply With Quote
Old 05-29-2011, 02:25 PM   #2
Rewards Points: 1,092
No foil; exterior should be as vapor open as possible. While at it, can you install one or two inches of insulation and a rain screen? Are you installing a WRB (water resistant barrier, like Tyvek or asphalt paper)? 1/2" is almost not worth the trouble, IMO.
Old 05-29-2011, 05:37 PM   #3
Mr. Handy
Rewards Points: 16
I will be using Tyvek and around here a lot of the siding installers use Rboard for residing jobs.
Old 05-29-2011, 05:54 PM   #4
Rigid board for a rain screen, of sorts, or for R value? Is R2.5 worth the trouble? Dunno; your call there. It is something, and avoids extending window frames or new windows.
Old 05-30-2011, 11:04 PM   #5
Registered User
Rewards Points: 4,924
http://hubpages.com/hub/Does-Foam-Bo...lp-Save-Energy
Gary
rigid foam board and height ctkeebler Building & Construction 4 01-09-2010 03:42 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 05:05 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 07:57 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
sagging roof, rotten ridge board sonoflee Roofing/Siding 6 01-29-2008 07:12 PM
