Exterior Foundation And Veneer Cracks - Fill It In? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 07:30 PM   #1
Exterior foundation and veneer cracks - fill it in?
I recently bought a new home and there are some exterior cracks that were noted. I was hoping to find some advice on what to do. I don't have any leaks but some of the cracks are ugly to look at, and it annoys me when I see ants traveling along those cracks.
1) Fill in those cracks using concrete caulk tubes (although after some research, I feel like that doesn't last very long and is very temporary).
2) Do a crack injection (but since there is no water leaks, is this overkill?)
3) Have a more skilled inspector look into this (mason?)
4) Do nothing?
Here are some of the different types of cracks I've taken photos of:
A) This is the foundation to an attached garage (no insulation)
Inspector says: Vertical cracks observed. This is an indication that previous settlement/movement has occurred at this location. Inspector is unable to determine when settlement/movement occurred or if additional settlement/movement is likely. Recommend monitoring for future movement.
B) This is a crack on the front porch area
C) This is a crack where the porch meets the veneer wall on the front of the house:
D) This is a small crack that runs along the chimney on the side of the house
E) This is a small hairline crack on the side of the house I can probably ignore
DIY advice appreciated. Thanks!
n0chance is offline   Reply With Quote
concrete , crack , foundation , hairline
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 06:39 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 04:03 PM
Cracks Above Archway in Brick Veneer sandarm Building & Construction 15 09-18-2009 07:05 AM
