Exterior Filler For Hole In Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 05:54 PM   #1
Exterior filler for hole in siding
What do I use to fill in gaps from a hole drilled for my Hvac lines
jclee is offline   Reply With Quote
Old 05-23-2013, 06:54 PM   #2
funfool's Avatar
Rewards Points: 534
would help if we knew what type of siding you have and how big the gaps are.
Typically caulk and paint.
funfool is offline   Reply With Quote
Old 05-23-2013, 06:54 PM   #3
Rewards Points: 79
If you mean the space around the AC line set you can use duct seal putty,like clay, spray foam, or exterior caulk.
Ebierley is offline   Reply With Quote
Old 05-23-2013, 09:20 PM   #4
Sorry. It's like 3 inch hole with ac lines coming out of it. There's about an inch gap all around
Old 05-23-2013, 09:31 PM   #5
funfool's Avatar
Rewards Points: 534
no problem, but still no help.
Is this lap siding, T1-11, stucco, vinyl, aluminum. A 1" hole will need some packing, what the siding is made of would decide what product I would pack the hole with.
Old 05-23-2013, 09:36 PM   #6
It's hardboard. Mdf I think.
Old 05-24-2013, 07:35 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
get a quality sealer like silicone except get one that is paintable, silicone is not. seal it up- let it sit a few days to cure, if needed seal it up again once its cured and let sit a few days more and then paint. usually the hvac guy will seal up penetrations if they make them...
hand drive is offline   Reply With Quote
How to Nail New Siding Under Existing Siding Shuriko Building & Construction 25 05-21-2012 08:33 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
