Exterior Electrical Boxes And Board Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 11:14 AM   #1
Rewards Points: 252
Exterior electrical boxes and board insulation
I'm building an addition, and planning on the following wall setup:
Gypsum board, vapour barrier, 2x6 studs with fiberglass insulation, OSB sheathing, Tyvek, 1.5" rigid board insulation, 1" strapping, wood siding.
I plan on having some exterior electrical boxes (outlets, lights, etc). What type of box should I use and how should it be flashed? I was thinking of screwing a plastic box to the osb, and then use peel and stick window flashing to tie it into the tyvek, as well as some caulk where the wire comes through the wall into the back of the box. Is there a better way?
shazapple is offline   Reply With Quote
Old 01-14-2013, 07:56 PM   #2
Registered User
Rewards Points: 5,216
Just to comment on the foamboard... If near Bathurst,NB; 1-1/2" XPS (R-7.5) w. R-19 cavity, would give you inside-face sheathing condensation at 24*F and below at 70*F inside room temp. That's 17% RH... Where are you located?
Some AK mobile test results in a nut-shell; http://cchrc.org/docs/reports/MTL2_final.pdf
Gary
Attic Insulation - Baffles, Air Flow Questions majch Insulation 7 03-25-2012 12:04 AM
Adding foam board insulation & plywood to underside of roof sheslostcontrol Insulation 1 05-04-2011 08:08 PM
Foam board and electrical boxes Master Brian Electrical 5 11-21-2010 08:03 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
