Exterior Door For 6" Wall - Where To Buy? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 12:28 PM   #1
Rewards Points: 150
Exterior door for 6" wall - where to buy?
I've looked at Home Depot and Lowes, neither sells a fire rated steel door/frame that fits a 6" wall. Are there sources to order these kinds of doors online?
sheslostcontrol is offline   Reply With Quote
Old 05-30-2011, 12:34 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Go to your local lumber yard, they can order whatever you need.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
thomasjmarino (05-30-2011)
Old 05-30-2011, 04:09 PM   #3
Rewards Points: 1,016
I have had the same problem with stucco walls (thicker) and will be doing 2x6 framing for a room addition with stucco this summer. I think the OP will have a problem knowing what to order because when I go to the lumber yard they have 1/2 dozen width differing door jambs. How does one determine which size to order?
Old 05-30-2011, 04:45 PM   #4
Rewards Points: 5,336
You measure your wall width and order one the size of your wall. Getting one a little smaller will just require adding a jamb extender to the exterior side.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
