Exterior Chimney Clearance - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 12:07 PM   #1
Exterior chimney clearance
Are there any professional masons out there that can answer whether or not 2" clearance (per code) between the sheathing/housewrap is required if adding a new chimney on the outside of an existing house?
thanks
DesDevInc is offline   Reply With Quote
Old 03-29-2011, 08:10 PM   #2
Concrete & Masonry
Rewards Points: 548
I have no idea what "your" code state's but here in WI, the requirement is only 1" of clearance on exterior walls, 2" on interior applications.
jomama45 is offline   Reply With Quote
Clearance for double oven installation Steeler99 Building & Construction 1 01-30-2011 05:16 PM
Furnace front clearance owner95112 HVAC 19 12-19-2010 12:22 PM
Furnace Clearance avtck HVAC 0 01-02-2010 09:13 PM
Duct clearance tjeieio HVAC 4 08-04-2009 07:37 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
