#1 |
Exterior chimney chase
Has anyone got any tips on building an exterior chimney chase around an 8" double insulated chimney off of a wood stove. My problem is we just had a hailstorm and it kicked the crap out of my stainless pipe, but instead of replacing it and waiting for another hailstorm I would just as soon build a box around it and cover it in. Has anyone done this so you can give me a few hints.
#2 |
Moderator
The pipe should extend 2' above anything within 10' to to bottom of the vent and be minimum 3' high including the vent to the roof surface. Fire-stop at attic and roof deck. Keep minimum clearance from pipe to combustibles. Frame the chase so the bottom of the vent is ? above the chase height, As per manufacturer. Frame the walls on the roof, assemble 2 together, then stand each set and nail off corners of last two joints. Install tin or aluminum chimney cap and flashing, caulk all nail-heads and paint. (Hint) Using ply or sheathing/Hardie, leave bottom of 2' off a side and the back, to nail plates to roof sheathing/rafters, and flash comp. before installing bottom access pieces. Hold wood above roof 2' and install step flash first with straight flash in chase wall.
Be safe, Gary |
#3 |
Thanks for the info.
#4 |
Moderator
You're welcome. And be careful up there!
Be safe, Gary |
| Display Modes | |
| drywalling over cold air return chase | avshockey | Remodeling | 3 | 09-08-2009 06:48 PM |
| Wire chase | jamiedolan | Electrical | 3 | 01-14-2009 10:19 PM |
| How to frame a gas fireplace chase | erikkl2000 | Carpentry | 9 | 12-02-2007 10:38 PM |
| Chimney Chase | Clutchcargo | Electrical | 7 | 10-26-2007 06:28 PM |
| New construction - Insulate Chase ? | Tcal | Building & Construction | 1 | 09-24-2007 08:29 PM |
