Exterior Brick Wall Seperated From Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2008, 02:11 PM   #1
Exterior Brick Wall Seperated from Home
I'm purchasing a home that has a problem with the decorative outside brick wall separating from the house. It has a 3" gap between the top of the bricks and the bottom of the roof line as shown in the picture. This gap runs about 6' horizontally and I believe the brick wall is loose almost to the ground. What is the best way to make this repair? The report I seen said that it's not accessible from the attic. Should I tear out the inside wall to place some kind of "standoffs" or do I do it buy removing bricks from the outside? I really don't know where to start.
Thanks,
Buddy
mrhonest is offline   Reply With Quote
Old 10-02-2008, 03:17 PM   #2
Rewards Points: 1,232
That is generally a sign that no wall ties were installed. Depending upon the wall maekup there are remedial anchors to fix it, but they are usually only done for commercial or double wythe masonry walls. Tear it down and rebuild it with wall ties.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 10-02-2008, 04:17 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
What did your pre-purchase home inspector have to say about the situation?
Have you closed yet? Any other brick veneer walls amy ahve been built the same way(same contractor) and are not showing any distress.
Dick
concretemasonry is online now   Reply With Quote
Old 01-15-2009, 05:06 PM   #4
Brick Veneer
Walk away from the house very slowly, then run like hell! If the builder scrimped here on brick ties or did such shoddy work elsewhere in the house you are buying into serious trouble down the road (and maybe not too far down the road!).
Thanks,
Buddy
Attachment 5256
Attachment 5257
unoga is offline   Reply With Quote
Tags
exterior brick repair
Church group trying to make T-11 look like a wall in a home we're redoing BJLower Carpentry 3 09-03-2008 07:43 AM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 10:11 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
