Exterior Basement Door Material Choice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 08:25 PM   #1
exterior basement door material choice
it's time for a new basement entry door. I can get steel, galvanized steel, or fiberglass. Looking for opinions on whether galvanized or fiberglass would be the best choice.
TIA
Steve_P is offline   Reply With Quote
Old 06-24-2012, 09:32 PM   #2
Rewards Points: 12,856
I'd go with a Bilco bulkhead in Fiberglass.
Old 06-25-2012, 07:09 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
I would get galv steel or fiberglass,regular steel will rust. some steel doors come with magnetic weatherstripping and helps create a tight seal when shut..
hand drive is offline   Reply With Quote
Old 06-25-2012, 08:20 AM   #4
Rewards Points: 3,130
A steel door would probably be less expensive, but I'd go with fiberglass. Another possible option is an aluminum-clad wooden door.
Wire Choice 12/2 or 14/2 Pentium Electrical 13 05-05-2011 04:33 PM
is Malarkey a good choice? analogmusicman Roofing/Siding 12 05-12-2010 10:48 AM
Need more power, Sub panel best choice? Hotel Electrical 6 03-07-2010 08:38 AM
Need help with unheated sunroom floor choice micimco Flooring 3 03-19-2009 10:00 AM
Correct Sub Floor choice jamiedolan Flooring 5 11-21-2008 11:48 PM
