Exterier Chimney Chase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 01:27 PM   #1
Exterier chimney chase
I'm boxing around an existing cinder block chimney. My question is, how close can my framing be to the cinder block? 4", 8", or can it be tight to it?
Matthewt is offline   Reply With Quote
Old 01-14-2012, 05:36 PM   #2
Registered User
Rewards Points: 4,888
If under IRC: http://publicecodes.citation.com/ico...003_par032.htm
http://publicecodes.citation.com/ico...003_par033.htm
http://publicecodes.citation.com/ico...003_par034.htm
always ask your AHJ
Gary
chimney chase leaks into attic dadscady Roofing/Siding 16 10-08-2010 04:04 PM
Building Chase Around a Brick Chimney TDFICH Roofing/Siding 2 05-17-2010 07:50 PM
Decorative chase for masonry chimney and radon vent? Badfish740 Building & Construction 1 05-03-2010 07:51 PM
Sealing chimney chase(?) cbrc5eric Building & Construction 3 03-15-2010 10:31 AM
Exterior chimney chase bronco2 Building & Construction 3 09-22-2009 02:26 PM
