Extension Foundations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 06:42 AM   #1
Extension foundations
I am planning to build a single storey extension to my home next year. There is an existing concrete slab in the place where this extension is going. It is 5 inches thick high strength well matured concrete. I am reluctant to go digging this concrete up to make a foundation for the extension. It is structurally viable and safe to buid on the existing slab or can I in some way put extra concrete overground to hold up the new building or is there some kind of overground lintel available?
gergac is offline   Reply With Quote
Old 12-27-2011, 08:39 AM   #2
Concrete & Masonry
Rewards Points: 548
Simply put, the addition foundation has to be of the same type of construction as the existing house foundation. If the house is sitting on a simple slab-on-grade, you "may" be able to use it, but not likely.
jomama45 is offline   Reply With Quote
Old 12-27-2011, 08:53 AM   #3
Civil Engineer
Rewards Points: 4,706
You need to discuss this with the building inspector. I assume you are planning to get a permit, and the local building code will undoubtedly have a section on allowable foundation types. In my jurisdiction, an extension on a slab would be totally unacceptable, foundation needs to be below frost, which is 4 feet in my area. However, you did not state where you live, so perhaps you do not live in an area subject to frost, and possibly you do not need a permit, so a little more information would be useful.
Daniel Holzman is online now   Reply With Quote
Old 12-27-2011, 09:08 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,504
This is an example of why it helps to have your location in your profile. What Daniel would do in Boston is not the same that would be done in California.
I am in the middle of a 2-story addition to my house. Exisiting house is raised foundation (crawl space). The addition is half slab and half crawl space. It was all pretty complicated....
Your soil conditions are going to be a big factor....as much as I am a DIY'r....this is one area where you need to hire an expert.....it's ok to do the work yourself....you just want to make sure your doing it the right way. That answer will not come from a DIY site.
If you want an example of how extensive my foundation is, have a look at the addition link in my signature.
ddawg16 is online now   Reply With Quote
Garage-Stucco extension separating from shiplap CandiceLynne Building & Construction 0 11-01-2011 10:43 AM
Permanent wire vs. extension cord Piedmont Electrical 7 05-04-2011 04:32 PM
Garage Door Extension Spring Question kmc143 Building & Construction 4 02-23-2010 08:24 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
