Extending My Deck. Sistering A 2x12 To A 2x6 Joist To Gain Riase Need Help - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 12:43 PM   #46
GBrackins's Avatar
Rewards Points: 2,108
if wood columns are supporting the existing beam you could install cleats under the new plies with through bolts couldn't you tony?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-14-2013, 12:53 PM   #47
Rewards Points: 502
Yes, perhaps like a pair of steel angles on opposite sides of each post.
tony.g is offline   Reply With Quote
Old 05-14-2013, 12:57 PM   #48
GBrackins's Avatar
I sometimes use preservative treated wood and run it down the column to the concrete under additional plies, this provides the code required support under the new plies. in my ocean (salt water) environment galvanized steel don't last, and usually they don't want to pay for stainless steel.
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
tony.g (05-14-2013)
Old 05-14-2013, 01:21 PM   #49
my lack of knowledge is going to come in here, how do i do this cleat thing
madmilitia is offline   Reply With Quote
Old 05-14-2013, 02:04 PM   #50
GBrackins's Avatar
a cleat is something that supports the additional plies that you'd add to the existing beam. it may be wood, could be steel angles. they go on each side of your column (if wood) and get bolted together. you could add a wooden member from the bottom of the beam to your foundation for the column. of course it goes without saying all wood used shall be preservative treated or of a naturally weather durable species. metal should be at minimum galvanized or coated, some preservatives used to treat wood are corrosive to metals.
Gary
Old 05-14-2013, 02:27 PM   #51
ok cool, i was also thinking of adding another 4x4 post so that this main beam is (2)2x6 with posts every 4 feet,
but whats the best way to do that, is it possible to digg a hole and fill with cement and just smash in a 4x4 or what would the best way be
Old 05-14-2013, 02:40 PM   #52
Rewards Points: 502
Old 05-14-2013, 02:45 PM   #53
GBrackins's Avatar
well I guess you could, but I CERTAINLY WOULD NOT .... go back and read post #42 again about footing. best to use a standoff post base connector to attach the column to the footing. How high is the deck off the ground (don't remember and don't have time to go back and re-read all the posts)?
Gary
Old 05-14-2013, 02:56 PM   #54
yeah yeah that is what i mean dig a hole somehow under this beam and fill it with cement and the put in the steel post base thing then put the 4x4 in the base and tap it in.
cause doesn't the post have to be super tight again the beam.
it's only likw 15 inchs from the ground.
Old 05-14-2013, 02:57 PM   #55
Originally Posted by tony.g View Post
lol is this cause cause you already told me to do this or cause i said smash it in.
Old 05-14-2013, 03:00 PM   #56
Rewards Points: 502
Old 05-14-2013, 03:02 PM   #57
GBrackins's Avatar
you could do that, or you could add properly size members to create a beam that would carry the load based upon the 8' span, either way works .....
Gary
Old 05-14-2013, 03:50 PM   #58
ok i'm going with adding 4x4 posts cause that seems easier, other then digging the holes under the beam that is already there.
Old 05-16-2013, 03:16 PM   #59
ok so i got footings dug and poured, and i found these cool brackets that allow you to tighten them once the support is in.
now the question of deck screws or nails, i've heard nails are better for the structure cause they can bend but i thought i woul ask you guys.
if you say nails what siz do i get?
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 12:41 PM
Connecting rim joist to deck ovahimba Building & Construction 5 01-19-2008 08:33 AM
