Extending My Deck. Sistering A 2x12 To A 2x6 Joist To Gain Riase Need Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 01:09 PM   #1
extending my deck. sistering a 2x12 to a 2x6 joist to gain riase need help
ok so i level off ground and put in an above ground pool, now i want to extend my deck out 6 feet so that the pool looks like it's under the deck.
my problem is i need to come up 6 inches, my solution is to sister 2x12's tot he excisting 2x6 joists and then use the excisting main support beam. this way i only have to create 1 more support beam near the pool.
i'm worried about struceral integraty though.
can 2 2x6 main support beam handle it if i siste on 2x12s and extend out 7 feet?
maybe this is better explaination
madmilitia is offline   Reply With Quote
Old 05-13-2013, 01:19 PM   #2
Old School
Willie T's Avatar
Mad Matilda,
Are you sure the joists lie the way you drew them?
Willie T
Old 05-13-2013, 01:28 PM   #3
Originally Posted by Willie T View Post
Mad Matilda,
yeah there is a main support beam that is 2 2x6 nailed togther that sits on 4x4 posts.
the joists are attached to the ledger board and run across the main support.
Old 05-13-2013, 01:35 PM   #4
MJ Force's Avatar
Rewards Points: 150
If your adding more deck you may want to increase the size of your beams. 2-2x6 might not cut it. Have a look at a span table also to help determine joist sizes
MJ Force is offline   Reply With Quote
Old 05-13-2013, 01:41 PM   #5
um not sure how to explain it, my deck is just like any other.
is this pic better all i have in paint
Old 05-13-2013, 01:42 PM   #6
ok so you don't think the current 4x6 beam that is there as the main support can handle 2x12's extending out 7 feet.
Old 05-13-2013, 01:54 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
the ability of a beam to support a load is based upon the length of the beam, the tributary load it must support and the species and grade of wood the beam is made from.
we know from the (2)2x6 you are going out another 7 feet, was is the distance from that beam back to another beam or the dwelling? what is the span of the (2)2x6 (distance between 4x4)?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-13-2013, 02:00 PM   #8
the span of the (2)2x6 beam from 1 4x4 post to another is around 8 feet. the distance from the main (2)2x6 beam to the other support beam (the one that will be by the pool i haven't put it up yet is 5 feet.
Old 05-13-2013, 02:06 PM   #9
MJ Force's Avatar
Rewards Points: 150
How wide is the distance between the post which supports the 3"x5 1/2" (or double 2x6") beam.
Your not try to cantilever 7' right? Your gonna create another beam next to the pool at a desired hight, right? How much cantilever over the pool do you want to create? Or do you?
Why not make the existing beam larger (check span tables) to match the new beam.
Have a look at some deck building techniques or search for deck plans on the net. Might give you some ideas.
It sounds like your trying to marry an old deck to a new deck while reaching out over the pool?
Old 05-13-2013, 02:11 PM   #10
GBrackins's Avatar
how far between the beam and one either back towards the house or the house itself .....
Gary
Old 05-13-2013, 02:12 PM   #11
Your not try to cantilever 7' right? Your gonna create another beam next to the pool at a desired hight, right? How much cantilever over the pool do you want to create? Or do you? ?
no i'm not cantilever, i am building another support beam at the pools edge,
Why not make the existing beam larger (check span tables) to match the new beam. ?
i'm not sure the best way to do this, if i marry another 2x6 to it will that be enough?
or should i just put in another main support beam right next to it with new footings an all.
that is correct, i have an old deck that sits 6 inchs to low and after measureing from the main beam to the top of the pool it's 12 inches which mean if i run 6x12's its at the correct hieght. my only concern is structural integraty
Old 05-13-2013, 02:13 PM   #12
Old School
Willie T's Avatar
Is this what you have in mind? Probably not a problem IF you intend to use (add) the red beam.
A lot depends upon how many support posts you have under the existing beam, and how far apart they are.
BTW, they are not that difficult to add.....
(You're looking at this from the house side.)
extending my deck. sistering a 2x12 to a 2x6 joist to gain riase need help-step-deck.jpg
Willie T
Old 05-13-2013, 02:13 PM   #13
8 feet to another beam that is on those elephant foot concreate blocks, and then 8 feet to the house.
Old 05-13-2013, 02:14 PM   #14
GBrackins's Avatar
I would suggest checking out the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide." This is based upon the 2009 International Residential Code. You would have to verify your code requirements with your local building department.
It is difficult to figure out something you cannot see. Some photos may aid.
Gary
Old 05-13-2013, 02:15 PM   #15
Is this what you have in mind? Probably not a problem IF you intend to use the red beam.
yes that is exactly what i'm trying to do,
now my main question will that already exsting beam support the 2x12s or do i need to add another support beam right next to it.
and yes i will be putting in the red beam
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 12:41 PM
Connecting rim joist to deck ovahimba Building & Construction 5 01-19-2008 08:33 AM
