Extending A Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 10:56 AM   #1
Extending a driveway
My driveway has a parking apron that was poorly designed in that it's too short. Cars parked there are an obstacle to backing out of the garage, so we are forced to park 4 feet into the grass.
I'm going to extend the driveway and need a little advice as far as standard practices. The addition will be 6' depth on a 20' wide apron.
Do I need a specif bedding? (Existing soil is sandy loam.)
Do I need any type of footing where the old and new slab will meet?
What size rebar should I use?
How far should I keep rebar from edges and surface? 4" (slab)
On what Centers should I create the grid?
How far into the existing slab should I drill to tie in the rebar?
Best form material to use on a radius corner?
Thanks.
gstuartw is offline   Reply With Quote
Old 07-19-2011, 11:33 PM   #2
Rewards Points: 150
What I call an apron is the flared portion where the driveway meets the street, It sounds like you want to make your driveway wider.
Do I need a specif bedding? (Existing soil is sandy loam.) Limestone 1" clean or minus I dont think it would matter what size you use but it must be compact 4"-6" deep
Do I need any type of footing where the old and new slab will meet? no
What size rebar should I use? dont know ?............I'd think #5 would be fine...........someone else may shine some light on this
How far should I keep rebar from edges and surface? 4" (slab) Dont understand the ?............ Maybe drill into the middle of the slab with a nice drill and bit to avoid cracking the surface.
On what Centers should I create the grid? Dont know but I would think 9"-12" would be fine
How far into the existing slab should I drill to tie in the rebar? Again I dont know
Best form material to use on a radius corner? Masonite but someone may have a better idea.
STL B. is offline   Reply With Quote
The Following User Says Thank You to STL B. For This Useful Post:
gstuartw (07-20-2011)
Old 07-20-2011, 08:07 AM   #3
STL B, thanks for your reply. The issue you were confused on...How far should I keep rebar from edges and surface? 4" (slab) had to do with placement of the rebar in the forms. I guess the "surface" part of the question was silly as common sense would dictate I center the rebar in the slab depth wise. Is there a common practice on how far from the edges of the slab one would keep the rebar from? Perhaps its not an issue other than aesthetics?
I build concrete counter tops now and then and position of rebar in the top is important to avoid ghosting as well as chipping or flaking adjacent to rebar too close to the surface.
Old 07-20-2011, 08:20 AM   #4
As for the terminology I chose perhaps "apron" is incorrect. Picture my driveway as a lower case "t". I have garages at each end of the arms of the "t" and the parking "apron" (as I call it) is the top of the "t" that extends out above the arms. I wish to extend the top of the "t" 6 feet. The width of the "apron" is 20 feet thus the 6'x20' addition to the driveway.
Hope this helps and again thanks.
Old 07-20-2011, 10:43 AM   #5
Concrete & Masonry
Rewards Points: 620
W/O surveying the site in person, I'd suggest a min. of 6" of 3/4" gravel.
No.
For the dowels, I'd suggest anywhere from 3/8" to 5/8".
For the grid, I generally use 3/8" on 3-4' centers. Anything larger in a 4" thick slab is overkill in most situations IMO.
Close to the middle, favoring the bottom if anything.
As for the edges & spacing, I'd stay about a foot in from the perimeter & any joints, and space them at about 2-3'.
Again, I tend to favor 3/8" on 3-4' centers.
IMO, 4"+
Thanks.
Depending on how tight the radius is, 1/4" Masonite/tempered hardboard for tight radius (~3' or under) and 1/2" siding for moderate radius, and 1x4's for long curves.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Lip between Garage and Driveway formed over Winter ivanl3 General DIY Discussions 4 02-27-2011 02:35 PM
we are extending our driveway but a small part of the area is spongy pinu Building & Construction 3 10-10-2010 11:50 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
