Extending Deck Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2008, 02:45 PM   #1
Extending deck joists
First time posting here and would appreciate some advice on building a deck. Size would be 10' X 20'. If I'm using 12' lumber for joists, what is the best way to join two boards together to get the length that I need?
rleabhart is offline   Reply With Quote
Old 08-25-2008, 02:57 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
What kind or a deck? - Free standing or supported by a ledger? Free standing is the most trouble free since the ledger support includes many problems. Are you letting the joist length you have decided on dictate how you design and build the deck?
Usually, you will need beams to support the joists.
I would suggest looking for design help somewhere to avoid wasting money.
concretemasonry is online now   Reply With Quote
Old 08-25-2008, 03:01 PM   #3
Whatamess
Sandwich them together on top of a support member. You ca nail or bolt them. Make sure you do it on the inside so it is not seen.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-25-2008, 03:34 PM   #4
I'm planning on putting 4 X4 posts into the ground. It sounds like I should center the two joists on top of the post
Old 08-25-2008, 03:49 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Why not use 10' lumber with 20' lumber?
If you can't pick it up, just get it delivered to your property by the supplier.
- Build Well -
Old 08-25-2008, 06:10 PM   #6
Rewards Points: 1,910
No,
Put the Beams on posts, put the joists on the beams. And definitely just get the right length and get it delivered.
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 08:16 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Double rim joists on Deck? Why? sandyman720 Building & Construction 2 05-27-2008 12:14 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
